Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Drywall height
  1. #11
    2,009
    Default Re: Drywall height
    The 3/8 or 1/2" gap at the floor, with the ceiling installed first, gets covered with the base molding. I can't see trying to cut or snap 3/8" stips of drywall.
    Having installed & finished drywall for a while many years ago, I never understood installing it horizontally, even though most reisdential work is done that way. I was doing commercial work at the time. One vertical seam to finish every 4' as opposed to a continuous horizontal seam at 4' and verticals every 8'.
  2. #12
    3,188
    I don't want the vertical butted seam that comes from horizontal sheet installation. I hang my sheets vertical too unless there are stud spacing issues.
  3. #13
    1,522
    hanging sheets vertically creates more joints that have to be taped.
    its harder on the taper as they have to kneel for 1/2 the joint, the only time a vertical butt joint will occur is if a room is longer than the sheets used. having a joint at waist height just means walking along taping it thus eliminating it becoming a two man task.. one guy up on stilts one guy hitting low spots.
    not only that but unless the taper is capable of doing a level 5 finish you will see every joint
  4. #14
    Tennessee
    2,016
    I know the convention is to use a filler strip in the middle, but since this filler strip is going to be so thin, < 2", I might suggest that you put it at the bottom where the joint will be covered by molding.
    If you are considering using crown molding in the room, then you could leave a gap at the top and the bottom and you wouldn't need a filler strip at all.
  5. #15
    Yep --- that pretty much sums it up.
    I've got some cousins with drywall companies and we joke about how rockers like the easy way
    One reason it works in the center is when the sheets are horizontal the seam is feathered out and in this case the 3 inch filler will blend in nicely.
    I do both methods -- vertical for smaller areas -- horizontal for larger areas.
  6. #16
    1,522
    pretty much the only times i will do vertical board are
    1) a section of a wall is less than 48" so the sheet can be cut to width then stood up
    2) temperary curtain walls for commercial construction when the board isnt going to be taped, its just there to help keep dust down and people from seeing inside. common for store front renovations
