Results 1 to 7 of 7
    Jan 2012
    Default Master Bedroom Renovation
    Inspired by the coming of a new addition to the family we are moving to the upper level of our 1910 Craftsman home. To make the room a master bedroom we want to knock out the two walls to open the room more. On one wall we will put an open closet and the other built in drawers. The question is can we knock down the current walls with out any structural repercussions? I do not know enough about construction in 1910 to know if the walls are keeping the trusses from separating or if they are there for weight bearing purposes. Any advice or suggestions would be wonderful.
    The link below is a youtube video of the room.
    youtube.com/watch?v=UCthaoeA36U
    1,387
    Default Re: Master Bedroom Renovation
    Howdy, one needs to determine if the walls are bearing the weight of the attic and or roof or not. Likely you will need to temp brace ceiling to keep from collapsing the building members and install a beam to carry the weight. So have a contractor out to inspect and tell you what is needed and the costs.
    3,179
    What Tim said plus;
    Most older homes weren't built to withstand adding more load. perhaps an engineer or architect would be a good second step after speaking with a knowledgeable contractor.
    7,762
    The above answers summed it all, plus only an engineer will give you the best answer to your questions.
    2,699
    An engineer is unnecessary most of the time. A good experienced contractor is usually enough of a knowledge base. If they aren't then they didn't fit the above criteria. Without seeing the situation nobody here can tell you for certain whether your idea will be as simple as it seems. My experience tells me that you will likely have some structural work to deal with- but it also says this is do-able with the cost and extent of the work needed being the bigger question.
    An experienced contractor could advise you if those walls are structural bearing however, it's best to have an engineer or architect design the appropriate changes.
    Besides , many building departments want to see professional stamped drawings when you apply for the permits.
    3,179
    Nice to see we are all in agreement.
    To be extra cleear, I mentioned the carpenter / framer / GC first because they are usually more out-of-the-box thinkers and may see more options than an engineer or architect. The hands on, experienced professional will also know the local codes and inspectors. Once a plan is decided, then bring in the engineer or architect if one is needed.
