Results 1 to 8 of 8
    St. Louis, MO
    24
    Smile Wood flooring on wall
    I have a unheated\ back porch, approx. wall size is 8' x9', can I apply flooring/laminate on the wall and if so what is the best way?
    STLOUIEY
    "The best house is an old house." "You can't fix stupid!"
    1,387
    Default Re: Wood flooring on wall
    Sure you can but why would you want to go to all that work and expense . Consider a good quality wood paneling much easier to install.
    St. Louis, MO
    24
    Question Re: Wood flooring on wall
    Not sure yet, as to what is behind the paneling.... This is a unheated porch. Thinking about insulating.
    STLOUIEY
    2,358
    I'd worry about the expansion and contraction rates of the flooring on the wall. I can see this going badly.
    St. Louis, MO
    24
    Just getting ideas... Makes sense... Could be a problem.
    STLOUIEY
    5,081
    I think it's a bad idea. These planks are called "floor" for a reason.
    St. Louis, MO
    24
    I have seen it done before! Just thought I would get ideas!
    STLOUIEY
    1,093
    Just because someone else got away with it is not enough reason to believe that you will get away with it too. Personally I can see no reason to attempt this, there are many great alternatives designed for wall usage that time has proven. If I had a truckload of this stuff, instead of using it here I'd trade it for a better material and yes- I'd insulate the exterior walls while you're in there.
