Results 1 to 10 of 17
    Jan 2012
    6
    Default Sprinkler System Removal
    Hi all,
    In the process of bidding on a single family that was previously a nursing home. There's a sprinkler system in the house that I'd like removed.
    I've heard from one person that if it's under a contract of some sort, the company that installed it will need to be paid to remove it.
    If that's not the case, I'd prefer to hire someone to drain the unit, then sell the scrap metal.
    Do any of you know procedure for removing a system like this?
    Nov 2011
    boston,ma
    114
    Default Re: Sprinkler System Removal
    If it is a decent looking system you might want to keep it, you will get a pretty good discount on your homeowners insurance policy, some new houses have to have sprinkler systems installed when they are built now by code. If it is a full system with pull stations and strobes everywhere then I would either change it to deco fixtures or just remove it if you are inclined on doing so! Good Luck!
    1,671
    I agree w/ jled96 abougt leaving the sprinkler if possible. Homeowner sprinklers are a bit different than commercuial systems however and it may be able to be modified to make it more appropriate to a house.
    If you want it removed, anybody can do it. Permits may be required. It will likely be connected to an alarm/alerting system that would need de-activating.
    6,694
    Count me too on keeping the system in place.
    More and more areas around the country get the classification of "fire zone" and residential fire sprinklers are being required in more homes than ever, so keeping what you have makes sennse just for resale value.
    2,969
    Add one more vote for keeping the system.
    Jan 2012
    6
    Thanks for all the responses!
    It's definitely a very commercial system. Pull boxes, all wiring is currently on exterior of wall, and the sprinklers aren't buried in the ceilings - just the pipes that run exposed through the house.
    If it were buried in the ceiling, I'd even leave the pull boxes and take the homeowners credit, but it's just very ugly and exposed.
    Assuming I did want to still remove it, what's the best way to go about it? Does the company that did it need to do it? Or can I hire a different company? I assume this could fetch some good scrap on a 3k square foot house...
    Nov 2011
    boston,ma
    114
    If you want it removed have a plumber/sprinkler fitter disconnect it for you, make sure there is no contract/lease on the current systems, if it is wired to a central alarm/fire panel that will have to be deactivated and removed,then you can take the sawzall and cut it up and bring it to the scrap yard. I would like to see you keep it, but if it is that ugly I can see why you want it removed, a few suggestions here, you couuld keep all the supplys and maybe in the future you could add some deco heads, and relocate the feeds into the walls, a sprinkler system is a good system to have , as everyone has said (re-sale value),or you could put in drop ceilings, could be drop in panels, or a sheetrock bulkhead, or maybee some false beams to hide the risers and heads. The pull stations can be removed and relocted inside the walls with standard gang boxes! Good Luck!
    Jan 2012
    6
    Thanks, jled. Do you know how to find out if there's a contract on the system? It was a nursing home until 2002 when it was sold as a single family.
    Nov 2011
    boston,ma
    114
    If it has been that long I doubt the contract would be still be in effect, I would make sure you get it in writing on your p+s agreement and make sure it is noted at the closing before you take possesion of the property, then just have your plumber/sprinkler tech. disconnect the main and take out the fire panel. If it has been that long the system might not even still be active, but definitaly check this before cutting any mains or risers,make sure the power is off to the fire panel and it is disconnected from your main panel before you remove the pull st****s and strobes/alarms! Good Luck!
    2,194
    If there was a lease on the system it's probably been vacated by now since the property has been transferred and they haven't contacted you about their property on the site. You might dig through old building permits and find out who installed the system then ask them. Me? If I didn't want to keep it I'd cap it off at the entry, disconnect anything else no longer needed, and cut it out myself without saying anything to anyone except my insurance company if they knew it was there.
    Some things of questionable legality are better addressed by claiming ignornace and begging forgiveness than by following legal procedure. Just research and know what you are doing before you do it and get severe amnesia afterward.
    In my county, it is illegal to set appliances by the road for pickup since they won't pick them up. Legally, you must take them to one of the county centers for recycling yourself or pay to have that done. But if you leave it by the streetside, within days someone who collects and sells scrap metal will relieve you of of the problem. If the codes enforcement guy comes by before it's gone, you get two weeks to correct the situation before fines are levied- by then Mr. Scrap Man has eliminated the problem. Not legal but it works and everyone does it here anyway
