    Jan 2012
    28
    Question Our house does not have ground wire
    Whole house does not have ground wire...just two wires ...looks like romex wires with pvc covering but only two wires in it..
    The service panel is metal and latest and copper wire(ground) connect to a rod which does in ground but inside the house from panel to outlets or baseboard heaters only two wires ..and not three.
    6,099
    Default Re: Our house does not have ground wire
    Not unusual for older homes. The bonding conductor provides very little in personal protection. One solution is to install GFCI receptacles and mark as ungrounded, a second solution is to run a ground wire from the panel to the receptacles, a third is to rewire. Updating to GFCI receptacles provides the greatest personal protection.
