    Jun 2010
    43
    Default Regrout or "refresh" grout?
    As happens, the grout seal on our tile bathroom floor hasn't done the best job, so we have some stained areas of grout.
    What solution would result in the best and longest lasting repair: re-grouting? Or, using a grout "paint" to refresh the grout?
    8,002
    Default Re: Regrout or "refresh" grout?
    Regrout and reseal. Why put a bandaid over it?
    Jan 2012
    8
    Regrout is time consuming and you have to be very careful not to damage the tile when removing old grout.......just remember which ever way you go sealing the grout is maintenance which means it has to be done every year or two
