    Dec 2008
    16
    Default Sump Pump Install
    I am going to put in a sump pump in the corner of my basement. I currently dont have one. Would it be easier to cut out the corner or should I just cut the circle for the sump basin? Ideas or comments would be appreciated.
    South*East
    1,257
    Default Re: Sump Pump Install
    If your going to put it in the corner stay at least 10" out from the foundation wall. There is a footing that extends out at least 6" from the walls that could be as much as 12" thick.
    John
