    Oct 2008
    6
    Default GFCI wall outlet not resetting
    Last night we had a bit of a storm with some lightning. I heard a loud pop that sounded like a breaker. We still had power, but I went ahead and check the two panels we have. All breakers were in the on position. Then I checked the two GFCI outlets we have. One needed to be tested/reset and it then worked fine. The other would not test/reset.
    I guess my basic question is, is it time to replace the one outlet? A yellow light is on. When I push in the reset button, it just pops right back out.
    Also, if I do have to replace it and it is currently a GFCI, it will be a direct swap correct?
    3,177
    Default Re: GFCI wall outlet not resetting
    GFCI's are vary sensitive and probably needs replacement but before you do - take the time to make sure the breakers were turned all the way off then all the way back on first. Some breakers trip 'half way' and need to be turned all the way off before properly resetting themselves. Its worth a try before you head to the big box store.
    Columbiana, Alabama
    843
    Ditto and just immagine if you had a freezer on a GFCI in the basement. Always a good idea to check things out after a storm.
    Maurice Turgeon, http://thesemi-retiredelectrician.com
    Oct 2008
    6
    Thanks!
    Went home last night, tested/reset it again, and it is now working.
