Thread: Exhaust fan
    Nov 2011
    15
    Default Exhaust fan
    I'm putting an exhaust fan in by bathroom and the directions say it needs to be protected by a GFCI which makes sense. Can i just put it in down line of a GFCI outlet or do i need to use a GFCI breaker? is there pros/cons to either method? Thanks.
    6,080
    Default Re: Exhaust fan
    Either way will work. The advantage of going off a local GFCI outlet is the you can reset it locally rather than going to the service panel in your bath towel.
    Jan 2012
    8
    I agree with JL - Down line of a GFCI will work the best for the reasons stated.
    And probably a lot cheaper than a GFI breaker.
