    Apr 2009
    Default Desert home humidity
    I own a 2nd home in Palm Desert CA that I will be closing up in mid May through mid October. Is it advisable to fill large buckets with water to add humidity and keep wood furniture from drying out? I do plan on setting my AC to 83 degrees.
    Feb 2009
    693
    Default Re: Desert home humidity
    Just live the life.
    6,005
    A humidifier would be the most logical choice. You're in the desert and the AC is a dehumidifier.
    1,387
    Howdy your wood floor has a 6% moisture content which is very hard to get below this %. I would not leave any buckets of water if your ac goes out there is a very aggressive mold that grows in desert environments in warm homes.. Consider calling a flooring store in your area an ask them if they have any other recommendations as they will have vast experience with wood floors and your climate.
