    Jan 2012
    Question sewage system psi
    Does anyone know what the pressure is for the sewage system in clay county, mo? i have been searching the web and i cant get any hits. please help!
    South*East
    1,208
    Default Re: sewage system psi
    Are you asking what the testing pressure should be? Or what pressure should be on the system? There should be 0 pressure in a DWV system that is one of the reasons for vent piping.
    John
    Jan 2012
    Quote Originally Posted by johnjh2o View Post
    are you asking what the testing pressure should be? Or what pressure should be on the system? There should be 0 pressure in a dwv system that is one of the reasons for vent piping.
    John
    the pressure in the system. I read up on it in case file and it should be a gravity feed system. The house was built in the early 1930's. Would this be correct?
    2,942
    The pressure outside your house and in the street? That depends on how hilly it is and if there are any in-line pumps in the system.
    As far as your house and it's connection to the public system, the pressure would still be zero.
    If you are thinking the public sewage is backing up into your pipes that can happen if the downhill pipes (relative to your home) are clogged or partially clogged giving no where for the up hill sewage (yours and your neighbors) to go. But I can't see that from here.
