Results 1 to 1 of 1
    Apr 2009
    Question Leaking 6gal inseries hotwater heater
    Because the main hot water heater is 40 ft away from the bath rooms, I installed an 'inline' 6 gal supplemetary hot water heater. Six years later now, that 6 gal device leaks a cupful of water per shower from the safety valve. I changed the valve and even tried turning down the temperature of the main 50 gal hot water heater.
    Should I install an expansion tank at the feed pipe to the 6 gal device (coming from the main water heater HOT output)? I notice there is such an expansion tank at the feed to the main hot water heater.
