Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Default Re: Grout over caulk
    BTW, when you get to 15 posts, we expect to see pictures.
    Now, get off the computer and get back to work!
  2. #12
    nova scotia, canada
    1,522
    normally i dont argue with spruce about anything other than who makes better beer but in the case of the chisel i will
    a cheap chisel is fine, however using a dull one will only cause problems. it wont cut as cleanly and will cause more effort.. when using a dull tool you will force it more which can slip either scratching the surface or risking injury. this past summmer i had to recaulk all the showers and tubs of 4 floors in one tower of residents at one of the local university's i tried dragging out the life of my chisels however found myself carrying 2 or 3 and having to sharpen them on every day.
    i know guys that coat the caulking with acetone overnight which softens the silicone making it easier to remove however it is a very powerful solvent which isnt the best thing to be breathing
  3. #13
    Not if you know what's good for you!
    I understand what you're saying, and I don't disagree about needing a sharp chisel for "shaving" the old caulk. In this situation, however, it sounds more like a layer of grout needs to be removed before one can get to the caulk.
    When I'm using a chisel on grout or slag of any type, I'm using it more to focus the force I'm applying in a manner that will "pop" the offending debris off. IMHO, a utility knife and paint sc****r will provide any cutting or shaving action needed so there is no need to hose my good chisels.
    This might be a case where more than one method may work, but just in case, do it my way! (I'm completely teasing if that wasn't clear )
  4. #14
    nova scotia, canada
    1,522
    your american spruce... your way doesnt work
  5. #15
    Jun 2010
    40
    i use a 5 way painters tool with a hammer head you have a choice of different sides to use also very sharp will least likely scrach the tub plus you have better control with the large handle best of luck
  6. #16
    Jan 2012
    8
    I use a utility knife with a brand new blade first slicing downward the sidways .....followed by a 1 inch putty knife to sc**** it off
