    Jan 2012
    Default Adding insulating value to existing windows
    I built a frame out of 1/2" x 1 1/2" material I ripped from 2 x 6 lumber. I added shrink window film to a frame I build and then installed the frame with the shrink window film approximately 4 inches from the glass in 6' x 5' windows. What is the best distance to install the film that is attached to the frame from the glass? If the film is to close to the glass, the R-value will be small. If the distance is to far from the glass, eddy currents will form and decrease the R-value. I call the manufacturer but received no useful information.
    1,977
    Default Re: Adding insulating value to existing windows
    Based on your description I doubt that much matters as there will be enough air leakage to negate any difference in the enclosed area. That's not saying they won't help- they most certainly will.
    R-1 equals one inch dead airspace, R-2 two inches etc. You'd have R-4 if both the window and the storm were essentially airtight- that's highly unlikely here. Your main gain is from loss of direct conductivity through the glass as well as slowing the total air movement, thus the actual R- factor is much less of an issue. Just set them where they will seal decently and are easy to install and remove, then enjoy the savings!
    Tennessee
    1,710
    You are correct in your assumptions. According to "From the Walls In" by Charles Wing, the optimum spacing is 3/4"(0.75"). If you use a mirrored tint on the exterior glass, you will increase the r value some more.
