    Jan 2012
    Default replacing recessed lighting.
    Is it possible to replace recessed lighting with a pendant light where the new canopy is smaller than the existing recessed light halo (the thing that covers the hole in the ceiling and where the light bulb comes out). I bought the new pendants sight un-seen.
    Columbiana, Alabama
    792
    Default Re: replacing recessed lighting.
    Quote Originally Posted by moromoro View Post
    Patch the hole...then make a smaller one?
    Maurice Turgeon, http://thesemi-retiredelectrician.com
    May 2011
    99
    I'm a novice, but it seems you will also need to install a ceiling fixture box for the pendant light. If the current recessed light hat box is between 2 joists, you will have to position the new fixture box over the hole and complexity depends on whether you have access to the ceiling from above.
    I had a flat (foam) roof house that every ordinary change was impossible because there was no roof/topside or foundation access. I could not pull additonal circuits, add new outlets except by tapping existing ones, or add ceiling boxes; nothing, but we liked the house better than the new McMansions.
    Aug 2011
    Northern Indiana
    96
    Retrofit pendants are available for recessed fixtures.
