    Sep 2007
    178
    Default Sub-panel mounting
    I want to install a sub-panel on the far side of our house to facilitate wiring in the garage for setting up a shop. I was planning on putting the panel in a utility closet but after poking around I discovered that may not be within code. My understanding is there must be a clear area around the box 72" high, 36" wide and 36" deep (see the attached picture). Is this true? Should I not put this sub-panel in a utility closet (which has a waste pipe nearby that would go into this clearance space) Or do these rules only apply to the main panel and not to sub-panels?
    Thank you for any advice you can give.
    -Walt
    Attached Files Attached Files
    1,387
    Default Re: Sub-panel mounting
    Howdy, is the garage attached? If not its usually not a huge job to run wire under ground... Sub panel in the garage shop allows easy access to breakers.
    Sep 2007
    178
    This new sub-panel is for an attached garage. The panel will eventually feed a new detached building...but for the time being I am concerned about feeding machines in the existing garage.
