    Jan 2012
    Default Dip in a floating floor
    We installed a floating floor this last December. We thought we did a sufficient enough job making it level 3/16" over 10 feet but we clearly missed some areas and have some dips when then floor is stepped on. Repairs are never easy but is there a way to fill the dips without taking up all the boards, padding and moisture barrier? Any advice would be greatly appreciated.
    Default Re: Dip in a floating floor
    What's underneath "all the boards,padding and moisture barrier"?
    Jan 2012
    Sorry about that. Concrete
    2,737
    In a word- no. Just be sure the 'dips' aren't the flooring buckling upwards before you go back and do the job right this time. I wish I had better news, but this is how you learn the following:
    Rule #1- Nothing can be better than what is supporting it.
    Rule #2- Shortcuts will bite you in the butt almost every time.
    Go back and level the surface as good as you possibly can then reinstall the flooring. That is the standard to aim for in every project, Never aim to meet only a minimum requirement, but always do it as well as it can be done.
    Your problem is in your uneven, unleveled concrete, and the solution explained above is the only GOOD solution there is.
