Results 1 to 7 of 7
    Jan 2012
    Default "rocket anchor" for chalklines
    Some years back, maybe ten, I found this line anchor and bought a few. I am looking to purchase new units. They're ****** site does not come up through any search engine (possibly closed, no longer in business?) Can anyone out there help me locate these? Thanks in advance! Kevin.
    7,240
    Default Re: "rocket anchor" for chalklines
    Can you describe them better, post a picture or provide a link to something similar?
    Jan 2012
    it's approx 2" long by 5/8" diam. in the shape of a rocket. Metal pin to stick in mat'l to be chalked to hold it in place on one end. This unit works best when cutting long slash cuts in plywood or when by yourself snapping layout lines. the normal line holder is held in the "rocket". I'll attch a pic tomorrow or day after. This thing is a great time saver.
    7,240
    You will need to host personal pictures elsewhere and link to them because members with fewer than 10 posts can't upload images. Spammers have ruined things for everyone.
    2,203
    Were these blue and yellow? I seem to recall Irwin offering these some time ago- they were essentially an over-engineered thumbtack I think it was at the orange big-box where I saw them. An Awl will do the same job and many others too
    1,522
    stanley makes something similar now which is in the fatmax line of tools, just check the hand tool isle at home depot.. ive only ever seen one in use once and that was some time ago.. the guy who had it just bought a new chalk line and it came packaged in with it
    theres another product along these lines called the "V-LINE" its basically a small clamp that has a slot where the chalk line hook goes into. it looks like a chip bag clip, i know many production framers that use them. when your not using it, it can simply clamp on to your tool belt instead of floating around in a pocket full of nails or other hand tools
    2,203
    Yep, you're right! It wasn't Irwin at all. Here's the link:
    http://www.stanleytools.com/default....3B+Line+Anchor
    Thanks for setting me straight!
