    Apr 2009
    warwick,ri
    Cool relocating a sump pump
    im making a family room in the basement and the sump pump is rite in the middle of the room. is there any certain reason why its in the middle of the basement or can i relocate it to the corner.
    Feb 2009
    693
    Default Re: relocating a sump pump
    Sure, mine is in the corner. Why not says I.
    Pennsylvania
    246
    Quote Originally Posted by gchiaril View Post
    It depends on the floor level.
    I think your floor is sloped toward the middle.....that's probably why the pump is in the middle.
    You may think the floor is level but check it out, you’ll be surprise.
    "Life does not go by the book, we learn as we go along".
    You only need two tools in life - WD-40 and Duct Tape.
    If it doesn't move and should, use WD-40.
    If it shouldn't move and does, use the Duct Tape.
