    1,387
    Default rims joist insulation foam need a fireBlock?
    Howdy reading about how one needs to protect foam insulation from the spread of fire... So when i install 2" of foam between the floor joist do i need to then install a fire blocking ? Then i plan on installing fiberglass batts to reduce the heat loss threw the floor into unfinished basement.
    2,009
    Default Re: rims joist insulation foam need a fireBlock?
    I don't have access to the building code at the moment, but I know thw latest IRBC does not allow exposed foam in an attic, so I assume it wouldn't be allowed in a basement. Coverage can be minimal with metal, plywood or gwb.
    Quote Originally Posted by Timothy Miller View Post
    Yes , you have to cover the exposed foam with a fire rated material like drywall for example.
