Results 1 to 10 of 12
    Dec 2011
    Default extending width of rafters for insulation
    My son purchased a 1940's home and we plan on making the attic space a bedroom. The roof rafters are 2x6 on 24" centers, we would like to add as much R value insulation as possible. Our thought is to extend the depth of the 2x6 by adding or attaching a 2x4 to the rafter, making it now a 2x10. Our thought was to glue and screw the 2x4, then add 9.5" batts for an R value of 30. Then, attached to the added 2x4, we would cover it with 1/2" drywall. There would be a ceiling about 8' tall and a 4' knee wall. Is this doable?
    thanks
    tom
    2,969
    Default Re: extending width of rafters for insulation
    Certainly doable but would you want to?
    Normally insulation should not be in direct contact with the plywood of the roof system. You'll collect moisture there and cook the shingles off the roof.
    You may find spray foam insulation a better option when combined with a venting system for the roof sheathing.
    Dec 2011
    Hi HustonRemodeler
    My plan was to use those foam panels that allow air to move from the sofit to the ridge vent. The problem with high density foam is it must be done by a professional and the CO$T. hoping to keep the cost down and the R value high.
    thanks
    tom
    2,969
    sounds good to me Tom
    1,522
    regarding spray foam insulation, yes it does HAVE to be done by a professional. they have the gear both to spray and to protect themselves from breathing it in. its also 3x the cost of batt insulation.. locally 2lb foam is $3.75 a sq/ft and 6 lb foam is around $5
    1,174
    Hi,
    I would put in 6" r-19 batts, then cover the whole thing with 2" rigid foam for another r14, use 3" drywall screws to hang the rock. You end up with better than r33, and save an awful lot of lumber. And the foam spanning over the rafters gives a full thermal break. So you can also decide whether to put in baffles and ridge vent it.
    Casey
    May 2011
    251
    Use open cell spray foam and completely seal the attic space. Any air movement through fiberglass and it's R value drops fast. Trying to vent effectively in a narrow space.
    The measured shingle surface temp in the field of sealed attics vs. vented attics is 5-10F depending on conditions. That might matter in AZ, but not so much anywhere else.
    Sealed attics stop air movement. You'll find that the downstairs is less drafty as well.
    I've read of one person venting an attic that was sealed and finding that it made his home drafty and cold because it accelerated the natural stack effect in the house.
    6,539
    All good suggestions. I'd choose sombreuil's, and here's why:
    1. you can do it yourself.
    2. not so expensive.
    3. very effective.
    4. no fumes, no mess.
    make sure you don't forget baffels. Ridge vent may or may not be necessary depending on your current vents.
    2,969
    I've done the layered insulation board method before with great success. 2 layers with staggered joints works very well.
    Dec 2011
    Thanks everyone, great information. never thought about what sombreuil_mongrel suggested. Have to think/plan that one out. Just to make sure, the 3" screws going through the 2" of rigid foam should hold both with no issues? Should the foam board be glued to the rafters? What type of foam board should I look for and should it be faced?
    thanks
    tom
