Results 1 to 7 of 7
    Nov 2011
    12
    Default Laminate Flooring (Which Direction?)
    I am laying laminate flooring in an attic. I would like to lay it with the long direction of the room. Can anyone here PLEASE take a look at the layout I've attached, and tell me which wall I should start on, and which direction I should lay the flooring to prevent the most waste?
    Thank you!
    Code:
    img248.imageshack.us/img248/2900/500wr.png
    Nov 2011
    12
    Default Re: Laminate Flooring (Which Direction?)
    Oops, forgot to add... Each board is 47.83'' Long, and 7.76'' Wide.
    6,751
    You are going to have waste either way, but if you start with the 25'-13/4" wall, you will have less waste.
    When you are standing infront of the wall, start from the left corner (the intersection of the 25'-13/4" wall and the 7'7" wall).
    When you lay your first row, start with a full plank and when you reach the wall on your right hand side, cut your last plank to size and use the 'waste', if it's longer than 8", as the starting plank on the second row all the way to the left. Continue this way, and you'll have the least waste.
    Good luck.
    2,969
    Generally the flooring is laid perpendicular to the joists.
    South*East
    1,227
    That would be with flooring that is nailed down. I believe there talking about a floating floor. In that case it can be install in either direction.
    John
    6,751
    Addition to my post above: I neglected to mention that my answer is true for on slab installation (free floating, as John mentioned), since virtually all of our installations are over concrete and moisture barrier.
    Thanks John for the clarification.
    1,522
    run it the direcetion of the longest wall, this way you reduce the amount of cuts you have to make
