    Dec 2011
    Default Support pole removal
    Hi,
    We have a older Wausau Prefab home dated around 1975. There are 2X8 boards 12' lengths sandwiched together 4 wide going the entire length of house where the 2 modules connected in the center. It appears that every 8 feet, there were support poles installed. The house has cathedral ceilings and at the highest pitch, they have a 3 foot wide support built across the ceiling in the living room. My question is whether or not I can remove the pole under the living room as it doesn't appear to be supporting anything and the 2X8 beam construction would carry the load?
    Default Re: Support pole removal
    Quote Originally Posted by Racechaplain View Post
    Hi,
    The support columns are there for a reason --- the floor rests on this main beam which is intern being supported by ALL the columns --- so --- no you can't just remove one without getting a structural engineer to recommend some other support mechanisim.
    Dec 2011
    I thought maybe the 4 sistered 2X8's would have a span rating able to cover the 16' span that is there....
    If that were the case then the design wouldn't have one there in the first place.
