Results 1 to 7 of 7
Thread: No ground wire
    Dec 2011
    Default No ground wire
    The new lamppost top I purchased does not have a ground wire, but the electricity coming from the post does, what should I do to ground
    Default Re: No ground wire
    There should be at least a grounding screw on the lamp body for the ground wire to attach .
    That's hard to believe, especially for a new post right out the box. Are you sure you didn't overlook? check the box again. Could you have purchased a box that was returned to the store?
    Option 2: return to the store and ask for an exchange.
    wisconsin
    159
    if the lamp isnt steel this might make sense, if metal something isnt adding up!
    May 2011
    251
    If its all plastic or glass or fiberglass, I'm not sure if it needs a ground. Why would it? There's nothing to ground.
    But yes, if it's metal... check the instructions. But it should have a ground or a screw or lug to attach a ground wire to.
    6,054
    An outside lamp post should be protected by a GFCI, in my opinion a ground wire would add virtually no protection.
    Aug 2011
    Northern Indiana
    111
    May be it "should be"but it is not required tobe.
