Thread: 6x6 post
    Dec 2011
    Default 6x6 post
    I have a 6x6 post that is supporting a deck and the 16 x16 shelter when I notch out for the 2x10 does that compromise the support value of the 6x6 to hold the roof help
    Default Re: 6x6 post
    Not sure what you're asking. Can you re-phrase your question with a better description of the situation?
    Dec 2011
    because i have cut a one and a half inch by 9 ad a half inch notch out of a 6x6 can it still be used as a post for my roof
    nova scotia, canada
    1,522
    yes it can, its fine, just be sure to add atleast another 2x10 to it and install carriage bolts through the post and beam
    I see what you want to do now.
    What jkirk says will work, but notch no more than 1-1/2" off the posts.
    I'd do it differently: use a 4x10 on top of the posts, with bolted Simpson connectors.
    Yep -- just like Mr. Kirk said -- I would also use construction adhesive.
    A *let in * connection like this is very strong. The 2x10 simply fills in the material you removed ( pretty much considered a squash block ).
