Thread: 6x6 post
    Dec 2011
    Default 6x6 post
    I have a 6x6 post that is supporting a deck and the 16 x16 shelter when I notch out for the 2x10 does that compromise the support value of the 6x6 to hold the roof help
    6,597
    Default Re: 6x6 post
    Not sure what you're asking. Can you re-phrase your question with a better description of the situation?
    Dec 2011
    because i have cut a one and a half inch by 9 ad a half inch notch out of a 6x6 can it still be used as a post for my roof
    1,522
    yes it can, its fine, just be sure to add atleast another 2x10 to it and install carriage bolts through the post and beam
    6,597
    I see what you want to do now.
    What jkirk says will work, but notch no more than 1-1/2" off the posts.
    I'd do it differently: use a 4x10 on top of the posts, with bolted Simpson connectors.
    Yep -- just like Mr. Kirk said -- I would also use construction adhesive.
    A *let in * connection like this is very strong. The 2x10 simply fills in the material you removed ( pretty much considered a squash block ).
