Thread: Room redo
    Dec 2011
    Geneseo, Ill.
    Default Room redo
    I am planning to start redoing the rooms in my house. Should I put plastic between the ceiling drywall and rafters? Would 1/2 drywall be ok for the ceiling? should I put new insulation in the walls and plastic on the walls also?
    thank yuo
    7,762
    Default Re: Room redo
    Where I live, a well vented attic doesn't require plastic between the ceiling drywall and the roof. But the midwest could be different.
    I prefer 5/8" drywall for the ceiling, with the right size screws, spaced correctly.
    Quote Originally Posted by tb1854 View Post
    thank yuo
    You're asking about installing a vapour barrier.
    I'll bet if you check with your local municipal building department they will probably say you require a vapour barrier --- so --- yes , if the ceiling has an cold attic above and definately insulate with a vapour barrier the walls.
    Only high density 1/2 drywall can be used for ceilings , otherwise use 5/8.
    Dec 2011
    Geneseo, Ill.
    Thank you dj1 and canuk...I will start the process then!
