Results 1 to 9 of 9
Thread: loseing heat
    Dec 2011
    chicago
    Default loseing heat
    my second floor does not heat up as well as the first floor
    7,762
    Default Re: loseing heat
    What kind of a heating system do you have?
    Dec 2011
    chicago
    i have a gibson heating an cooling system
    3,160
    forced hot air? water filled radiators? steam? hydronic?
    7,762
    Gibson is part of Nordyne. Most likely it's a forced air unit.
    Get a reputable HVAC guy to give you an evaluation on what to do:
    from checking your venting system to the size of your cooling and heating units. Your situation is very common.
    3,160
    Also check for adequate air return. Closing tightly fitting doors can choke off the return, which means the heat can't get into the room if the air can't get out.
    Dec 2011
    chicago
    Yes its forced air an i also dont have any returns up stairs
    1,387
    Howdy leaving the upstairs doors ajar so the air can circulate will help. Having a heating contractor come and check the flow rate at the vents upstairs an possible speed up the furnace fan motor is another easy help.First is the furnace filter clean change it every 30 dys during the winter is another great help...
    Dec 2011
    chicago
    thanks u all for the help!
