Results 1 to 9 of 9
    Dec 2011
    Default keeping my clearcoat "clear"
    I'm having trouble with the white paint on the boards that I paint turning yellow or amber when I put polyurethane on them...any suggestions?
    7,592
    Default Re: keeping my clearcoat "clear"
    Why are you putting poly over paint? Poly yellows with age.
    1,817
    As Spruce alludes to, quality paint does not need a top coat. Should, for some reason, you desire to top coat, be aware that all oil based varnishes/urethanes have a slight amber tone which will pull off the color of the underlying paint. However, water based urethanes are very clear. You can use it over an oil based or latex paint. If the underlying paint is glossy, dull it down with fine sandpaper to assure adhesion.
    I speak in generalizations. Always follow the label instructions!
    7,592
    Ah geez, now we're gonna have to get into a debate about what quality paint is!
    1,817
    Unhappy Re: keeping my clearcoat "clear"
    Lessons learned the hard way: years ago, I put a blue base coat and glaze finish over some dark 1960's paneling. As a protective top coat, I made the mistake of using oil based varnish. The next morning, that blue glaze had a very greenish look to it, due to the yellow tint of the varnish!
    I had to completely redo the blue base coat/glaze and then I top coated with a clear acrylic varnish.
    Live and learn!
    1,817
    Spruce, quality paint is Behr(ly) worth discussing!
    Dec 2011
    Thanks for the info...I'm putting poly on the boards (corn-hole game) to help protect the finish.
    7,592
    Are you Dunn, Edward? You sneaky bastid!
    7,592
    Quote Originally Posted by jbx2k View Post
    I think I'd go with lacquer, just do a test first to make sure that the lacquer is compatible with the paints you are using, otherwise you're going to get alligatoring of the finish.
