    Jan 2011
    32
    Default Removing 1 baseboard from circuit
    I have a hot water boiler baseboard heat system. I want to remove 1 baseboard from the beginning of my circuit for the winter. When I finish the basement, I want to add it back later, pushed over 10 feet.
    I want to know if removing it this winter would throw anything out of whack. There is already 2 in my basement, so I am not worried about the heat. I closely monitor it with sensors.
    Thanks.
    2,952
    Default Re: Removing 1 baseboard from circuit
    A bypass pipe will work just fine
