    Nov 2011
    Default Granite Behind Slide In Range
    Am changing from a slide-in to a free standing range. What is the best way to remove the 4" piece of grante that was behind my range? The granite is black so that makes it extra important for me to do the best job. It is seemed with grout and there is a piece of wood holding it up. Do I need a professional?
    6,767
    Default Re: Granite Behind Slide In Range
    Why do you have to remove it?
    2,969
    If it is seamed at both ends, then;
    1- Remove the wood
    2- Using a right angle grinder and a dry diamond blade, cut out the granite
    3- slide the new range in.
    6,767
    Quote Originally Posted by scipper View Post
    OK, I assume that the 4" piece is IN FRONT of the range, and not as you wrote "behind" the range.
