    Nov 2011
    Mississippi
    Question lighting upgrade -- suggestions please
    i just inherited a house and would like to update the kitchen lights. current lighting is fluorescent tubes on left and right walls 4 4ft tubes down each wall and and dual 2ft tubes over island counter. Left, right and center each have a switch. House built in the 70's. Lights are concealed in 6in space above cabinets where you only see lights if you look straight up.
    |...()...| <-- decorative whatever ya call it
    |... \----- light tube (arrow goes over and up, () is the light)
    |<-- wall
    what would be best for lighting. bright light, low power use, and would fit in the space? or should i just update to newer fluorescent tubes?
    wisconsin
    159
    Default Re: lighting upgrade -- suggestions please
    Kinda confusing.. but are you talking undercabnet lighting?? if so id stick with what you have unless you wanna spend money.. then skys the limit.
    240
    I think this may mean a soffit over a cabinet or simply a light concealed by trim. Regardless, a good replacement may be LED strip or puck lighting. Very low profile, high light output and low on electricity. LED lights may be a little more expensive although usually not by much but it usually produces better quality lighting than fluorescent in my opinion.
