    Nov 2011
    5
    Unhappy Clay Dam for sewer line
    We have an older home that has new subdivisions built around us at higher grades. The problem is that when it rains or the snow melts, the water follows the slope downhill in the ditchline and causes our sump pumps to run like crazy! We live in an area where there are no storm drains, only ditches to carry the water away. The soil is clay and the water seems to follow the underground, gravel-lined, ditch located main sewer lines until it reaches the residential sewer lines running to each house. It then follows the gravel filled "underground water roads" right the base of our foundation causing the sump pumps to fire like crazy.
    The idea that a plumber had given us is the dig out around the sewer cleanout in our yard down to the virgin soil. They remove the gravel and replace it with bentonite. I guess this is a clay like substance that hardens when exposed to water and will prevent water from flowing through it. They use the stuff to line the bottom of ponds to keep the water from draining out. So the idea is to build a "clay dam" to prevent the water from reaching the house and will prevent it from following the path of least resistance(at least the path to our house). It will continue downgrade following the underground sewer main in the ditch and should keep our sump pumps from running like crazy for weeks on end. When I say crazy I mean all 3 pumps run like every minute or so 24-7...This is causing me to lose a lot of sleep and I am looking for any help/advice I can get.
    Thanks so much!!
    John
    Nov 2011
    5
    Smile Re: Clay Dam for sewer line
    Anyone have any expierence with this? Heard of it? Positives? Negatives? Worth a shot? Any other ideas???
    Thanks All,
    Tennessee
    1,995
    Default Re: Clay Dam for sewer line
    Sounds good to me.
    If you have neighbors in the same situation, I would also suggest that you band together and get a good attorney. The city engineer or city counsel had an obligation before approving permits for the new subdivision to prevent this from happening. Now they have an obligation to solve the problem and if necessary, install storm drains.
    Sometimes you will find that the original developer did agree to provide storm drains, but does not plan on doing that unless there is a complaint. If the developer hasn't skipped town, or declared bankruptcy, you might be able to get this solved easily.
    If you are on your own, I see no reason not to try the clay dam. If you have a lot of neighbors in the same boat and you all do that, you might create another problem that you could be held responsible for.
    One more thing, when your sump pumps are pumping rain water into the sewer, you are adding to the load of the sewage treatment plant, so it is in the cities best interest to solve this problem for you. Again, if you are on your own, try the clay dam. Maybe you can even get the city to pay for it.
    Mar 2013
    12
    If you are going to use sodium bentonite for this be sure to mix it in with some local dirt, as it can expand 18 times its size when wet.
