    Nov 2011
    17
    Question Wood stain on too long...
    I've left a wood stain on a piece of furniture I've stripped and now stained for more than 48 hours by mistake. How do I remove the stain now? ...how do I remove the stain without having to start all over?
    Default Re: Wood stain on too long...
    Read the label on the stain, it should tell you how to clean up dried stain. This method can be used to remove the excess. Whether or not you'll have to start over will depend on the stain, the clean-up method, and the tenacity with which you try to clean it up.
    Nov 2011
    17
    Unfortunately, the label is gone from the can. Must have fell off in the move. Anyway, I'm going to sc**** and wash, and sand and wash and hope I get it all off.
    Thanks, Spruce!
    6,063
    Try washing it with paint or lacquer thinner. That usually works.
    If you know what the brand/type of stain was to begin with, a quick check on-line or at the hardware store will give you your answer, otherwise give Jack's method a shot.
    1,950
    JLMCDaniel is correct. After such a long drying time, mineral spirits may no longer lift the stain. If not, try lacquer thinner. I would use tufts of fine steel wool dripped in the solvent and rubbed with the grain. Wipe the residue raised with rags or clean paper towels. Be careful with the rags, they are highly flammable until dry! Also make sure your work area is well ventilated with possible ignition sources turned off. Lacquer thinner and acetone are quite flammable and explosive when concentrated. If an even more aggressive solvent is neccessary, progress to acetone.
