    Nov 2011
    Default Add Stool & Apron to Drywall Return
    All of the windows in our home have only a drywall return, not even a stool and apron. It's tract home so this was done for economy not design purposes. I would like to add a stool and apron only, not interested in adding any other molding and was wondering if I could just install the stool on top of the drywall. I've got about 1" of window frame above the drywall.
    Default Re: Add Stool & Apron to Drywall Return
    I don't see why not, if it's less that 1" thick.
    nova scotia, canada
    1,522
    ive done it, pretty simple, if you have 1" of the window frame to create a reveal go for it, you can use 1/2" stock as long as it doesnt extend out past the wall very far otherwise 3/4"
    i use this detail when i trim icf constructed buildings as doing a full window box chews up far too much materail, normally looking at 8 to 10" jamb extensions. that a ton of mdf on homes and buildings that can have 30 plus windows
    1,950
    It seems to me that with only 1 inch of the bottom of the window showing, if you don't remove the bottom drywall, you will only see about 1/4 inch of the window frame. I am not sure that that will not look a little odd? Admittedly, most window treatments would cover that edge anyway.
