    Nov 2011
    Default Roof shingle suggestion for coastal New England house?
    Does someone have a recommendation for roof shingles that can stand up to coastal New England weather? The house is exposed on a hill facing the water. Over the years it has been directly exposed to hurricanes and strong Nor'easters - so withstanding heavy winds is our main concern. Thanks.
    7,647
    Default Re: Roof shingle suggestion for coastal New England house?
    Get the opinions of local roofers. Those with experience, not those who just want your job.
    Shingles installed correctly, with nails (not staples) can take winds in the 70-80 mph range.
    But I'm sure you've seen images of flying roofs in tornadoes in the midwest. They won't stay put in winds over 80 mph. And if poorly installed, the take off in 40 mph range winds.
    Jun 2009
    NY
    35
    Architectural grade shingles..hand nailed!
    http://www.westchester-architects.com
    Nov 2011
    Thank you for the replies. Because of the way they seem to overlap and have that 3-D effect, I was worried that the lower edges of the architectural shingles might be pulled up by high winds, and then make the roof more vulnerable to damage. Are they strong enough that this is not an issue? Thanks again.
    7,647
    The dimentional/architectual shingles are very popular for their good looks and durability. Some of them even carry lifetime warranty. The top parts are attached to the base of the shingles with tar, and it's as they're fused together.
    Regarding the warranty: it's a limited warranty for workmanship, not the installation or a natural disaster. In other words, not very enforceable.
    Hope that answers your question.
    Nov 2011
    Yes, that helps. Thanks for the advice!
