    Nov 2011
    Default Washing Machine Water Hoses
    The hot & cold water hoses on my washer are rusted onto the shut off valve. I've applied penetrating oil but I cannot loosen the hoses. Any ideas?
    South*East
    1,241
    Default Re: Washing Machine Water Hoses
    Very carefully cut the hose fitting without cutting into the valve and peel the hose fitting off the valve.
    John
    3,120
    What John said plus;
    Use something slow like a dremel or used hack saw blade. A new blade will be more difficult to use. Cut on opposite sides if you can reach, if not, remove a section and then peel the rest away.
    Clean the threads well with a wire brush before re-attaching new hoses. Use stainless hoses and inspect more frequently.
