    Nov 2011
    Smile Smelly Hot Water
    This is a copy of a question I sent to Ask This Old House hoping for a reply soon???
    Hi: This ? is for that resident expert Richard Trethewey.
    I have that sulfur smell in the laundry room sink when the hot water is used. Here's the kicker: thatís the only sink that has this problem. I've tested other sinks, some closer the hot water heater(electric)but I don't seem to have that smell anywhere else. I know that thereís only one WH for the house(4yrs old) as I personally helped in it's construction. I have purchased a new anode rod but I'm hesitant to install it if there could be another explanation. Iím at a loss to explain this. Can you help???
    P.S. I love your show and watch as often as possible...
    Regards,
    JD
    Default Re: Smelly Hot Water
    Go ahead replace the anode and see if the sulfur smell disappears.
    3,201
    Just before final pipe connection at the top of the tank, toss in a quart of bleach then fill the tank. Let it set for 2 or 4 hours. Bleach is the standard way to rid HWHs of that sulfur odor. If the sink has a filter, remove the filter as they make the smell worse. Sounds counter-intuitive, but true,
    OKC
    247
    Are you sure its not coming from the drain?
    HOPE THIS IS HELPFUL!
    Oklahoma City, OK
