Results 1 to 10 of 13
    Nov 2011
    Default Radiator removal
    I want to remove a radiator to fix a floor. Can I remove the feed and return lines w/o interrupting the rest of the system? I can turn off the valve on the feed but do I have to cap the return line? Thanks. Joe
    South*East
    1,213
    Default Re: Radiator removal
    Joe you can't remove the radiator and keep the system running unless you cap the lines.
    John
    Jan 2009
    Needham, MA
    559
    you have to drain the heating system, fix the floor then re-hook up the radiator and refill the heating system.
    May 2011
    99
    Is the piping in series so he can't use the system until he re-installs the radiator ?
    South*East
    1,213
    Quote Originally Posted by Brookworld View Post
    I don't think so it sounds like it's a cast iron radiator. He said he had one valve on the feed. More then likely a one or two pipe system.
    John
    Nov 2011
    I think it is a 2 pipe system. I am basing that on the pipes that lead upstairs. Two pipes next to each other. I am guessing one is the feed and one is the return. Thanks for the responses. Joe
    May 2011
    99
    Quote Originally Posted by Lobo74 View Post
    I'm no expert, but they all have a "return" pipe back to the boiler. I was asking if radiators are "daisy chained" or "parallel" to the pipe. If each radiator has an adjustable input valve (as distinguished from a bleed valve), then temporarily removing the radiator still permits water through to other radiators in the zone/branch. Multi-dwelling houses are definitely NOT daisey chained, and they make new thermostats for individual radiators.
    My hydronic system, has 4 zones (separate branches), and I think, each zone has "daisy chained" baseboard heat emitters (radiators) so if I remove one emitter, water is cut off from the others in the zone and can't return to the boiler. The pump circulator would pump water and pressurize the end cap of the removed radiator section, and I wouldn't know what would happen. So, I would turn the system OFF while the radiator is out. (Maybe my radiators are not daisey chained, but I can't see evidence of one way or another).
    Don't know about your system, but you should know the possibilities before removing the radiator.
    5,804
    Without knowing the full system configeration it is best to drian the system. Shutting off the valve on the feed side will not stop back feed on the return pipe.
    24
    @brook world
    not all steam systems have a return line. there is what is refered to a one pipe reverse return in which case the steam is on top and condensate on the botton
    5,804
    Quote Originally Posted by perchinonlakeerie View Post
    @brook world
    The OP said feed and return line.
