Thread: Crooked door
    Oct 2011
    Question Crooked door
    The entrance door from our garage appears to have shifted. When you look at the door from inside the house the frame is straight but the door looks crooked. The door has also become drafty in a few places. Any easy fix or suggestions? Thanks!
    6,063
    Default Re: Crooked door
    First try tightening the hinge screws and see if that takes care of the problem. Also check the hinge pins to see if they are excessively worn. Check the crack around the door to see if it is even, if not you may have to shim some of the hinges. Playing cards makes good shim material. If the door is warped it may be necessary to replace the door.
    6,063
    Oh, by the way, just because a door frame looks straight doesn't mean it is. Check using a level on the sides and a square on the corners.
    First check and see if your door jamb is plumbed and squared (sides and front). If not, plumb and square it.
    Second, check the door. Use an accurate 4' level. If not plumbed, (sides, front and back) you can make adjustments. I can't tell which way to adjust, since I don't know which way the door is tilting. You must determine that yourself. To see some of the ways carpenters do it, go to Youtube.
    If the problem is in the hinges, you may have to use longer screws to make sure your hinges are fastened correctly and don't move.
    1,901
    After you've made sure the hinges are secure...
    If the door is actually square (checked with a square) but the jamb is not, your house has probably settled unevenly and you may have serious structural issues. Jacking up an unlevel house is not a DIY job for a beginner. (Or the jamb never was installed square in the first place.)
    If the frame is square but the door is racked, the door will need to be repaired or replaced. Repair of a racked door generally involves dismantling and regluing it.
    1,522
    you probably dont have to go as far as just mentioned. check the door for level on the sil, then check the jamb on the hinge side for being plumb
    if its not plumb you can take the door frame out and reinstall it so it is or make minor adjustments to get it workign properly again
