Results 1 to 8 of 8
    Oct 2011
    10
    Default Wood Filler Used To Cover Flaky Paint Under 5 Layers With 2 Layers Under Wood Filler
    I have NEVER in my life seen anything so assinine as how this was used to avoid scraping and painating.I have 7 layers of paint to strip off of maple window sills, window frames, doors, molding around doors and floor molding. Under 5 layers of the paint, is a layer of wood filler, which is on top of 2 more layers. I am assuming when putting on the 3rd layer of paint, the worker used wood filler to cover the flakes in the bottom 2 layers, instead of scraping and removing the old paint. I have called every contractor and individually owned paint stores I know for ideas and advice. Currently, I am using a regular sander, a finishing sander, stripper gel, acetone, fabric softener, a putty knife along with a razor blade sc****r.In 4 days of 8 to 9 hours work a day, I have one whole window sill and frame almost done, 1 halfway done, 1 1/4 of the way done, and one I'm just starting on. I use all these tools in a pattern. If you know of anything that can help me speed this process up, I'll kiss the sky.
    1,375
    Default Re: Wood Filler Used To Cover Flaky Paint Under 5 Layers With 2 Layers Under Wood Fil
    Silent Paint Stripper or heat gun, for starters.
    Casey
    1,929
    You might consider trying an electric heat gun. Stripping with heat actually works better when there are thick layers of paint than when only a thin layer exists. I assume that you are intending to re-paint the woodwork, so minor scorching would not be a problem. Electric torchs are somewhat slow, but propane torches are far too dangerous inside a house. Even if you don't get the surface totally clean, you would get it clean enough so that a thin coat of stripper would take the rest.
    There are also radiant electric strippers on the market, but these are pretty pricey - about $400.
    TOH has used a relatively new type of stripper on the exterior of some of their projects. It is non-toxic and will not give you a chemical burn. It is applied to siding and left to sit overnight. The residue justs pops off with a sc****r the next day. It was applied with an airless sprayer and the operator did not even have to wear protective gear. Unfortunately, I don't recall the name of the material and I don't know if it is suitable for interior use, although I think it should be.
    Oct 2011
    10
    Thumbs down Re: Wood Filler Used To Cover Flaky Paint Under 5 Layers With 2 Layers Under Wood Fil
    Thank you so very much, but the proverbial "BUT":
    <p>Before I invested in a heat gun I heated an iron to its hottest setting, and placed a wallpaper scrap which I'm also removing on a test area and acheived the same gooey mess and the same acetone clean up. I did get in touch with yet another contractor friend of mine this afternoon, who said he would do that same thing in a heartbeat instead of scraping the old pain layers off. This kind of remodeling work doesn't pay. I guarantee anyone if I took a job like this on I would charge 50 bucks an hour, in OK, where I am. On the left and east coasts, plus Florida, I'd charge 100 bucks an hour. This is insane.
    I've done all kinds of construction work and remodeling, but I know now I've NOT seen it all.
    Oct 2011
    10
    I don't know how to use this place, OBVIOUSLY! I didn't see your whole reply. I'll check that out, thank you!
    Oct 2011
    10
    OK, first reply was to first guy, and I only just now must have gotten the second reply from second guy, got confused and thought I didn't see whole first guys response! I'm getting it. I only have another 2 weeks for this room, but the rest of the house was also done the same way, so I need to find out and order some of that whatever you hear of from the TOH crew.
    Thank you SO much.
    Oct 2011
    10
    Does a brand name RemovAll ring a bell ordjen?
    Oct 2011
    10
    Oh, I'm not repainting the wood, I believe it's maple or maybe hemlock and it's gorgeous. I'm shellacing it. Then the walls are going to mauve with a darker mauve faux glaze. Spanish adobe style.
