    Dec 2009
    22
    Unhappy wavy subfloor fix??
    so the floor in my 1929 balloon frame colonial upstairs was shot but the subfloor is not exactly flat. I want to install a new floor and would like to use a laminate wood or engineered wood floor but I dont think they are all that forgiving of a warped subfloor. What can I level with (i cant use self level concrete) that wont add too much weight or what can I put down that will tolerate the warped floor? I see discrepancies of about an inch kinda like a soup bowl in a 16 to 20 sq foot area
    any ideas?
    7,586
    Default Re: wavy subfloor fix??
    Question, are you trying to fix an out of level floor or are you trying to fix an uneven/wavy floor?
    As far as unlevel goes, I don't think I'd worry too much about that. As far as uneven goes, you could easily fill the low spots with floor leveling compound.
    Dec 2009
    22
    My floor is wavy and uneven. Will the leveling compound help with that?
    7,586
    Leveling compound can be used to fill in the hollows easily enough.
    Jun 2009
    NY
    35
    rip up the old subfloor,
    sister new 2x6 alongside the exist joists level.
    http://longisland-architects.com
