Thread: cowvann
    Oct 2011
    Smile cowvann
    We are adding a stacked washer dryer to our 100+ year old summer cottage which has to be winterized. The washer-dryer needs to go in a tight corner. Do we need to pull it out to winterize it? If we need to get to the pipes behind it, how can we pull it out without tearing the roll vinyl flooring it will sit on?
    Thanks for your help.
    Default Re: cowvann
    If I understand you correctly:
    You can lift the double unit, with the help of a volunteer.
    Another way is to lay furniture moving discs under the washer and just slide it out and in. You can find them in many stores.
