Thread: wall oven
    Default wall oven
    I have a 1965 GE wall oven with a white door finish. The cabinet that it is installed in is too small to accommodate a late model oven so I am trying to determine if door can be repainted or not. I'm not sure if door is porcelain. Would heat from oven be a problem if it could be repainted?
    Appreciate any advise.
    Thanks
    1,387
    Default Re: wall oven
    Howdy consider using a high heat paint for appliances.
    If this is the exterior .... many auto body shops will spray your door.
    Apr 2009
    22
    yeah you can try using some auto body shops to paint it.
