Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    6,758
    Default Re: Could you give advice on a leaking lead pipe supply line?
    Farmer -
    Lead used to be everywhere. And so was cancer.
    They took it out of paint. They took it out of gasoline. They took it out of school supplies, toys, you name it...Now they're taking it out of plumbing - and rightfully so.
    The idea is, when a part or a pipe full of lead fails, to replace it, not repair it, with a leadfree part, slowly move from leaded to unleaded.
  2. #12
    Sep 2011
    Midwest
    37
    Much of what you are addressing is just politics.
    Home treatment devices often change the make up of the water. Softeners can make the water aggressive.
    We were talking about the service line coming into the home. In most hard water supplies, there is nothing attacking the pipe material in that portion of the service line. The water may not actually be in contact with the pipe.
    Replacing the water service can cost thousands of $$$.
    If it can be repaired, in most cases that is a better use of resources. i.e. homeowners $$$
    (Note: In old neighborhoods with lead water services, the sewer may be run right with the water service. Replace one, you replace both. More $$$)
    Again. Contact your utility for information on the water and your service line. Read your CCR.
    Waste not, want not.
    Use it up. Wear it out. Make it due, or due without.
  3. #13
    South*East
    1,227
    Quote Originally Posted by farmer52 View Post
    You are kidding!!! The adverse effects of lead have been known for many years. What would politics have to do with it?
    John
