Results 1 to 1 of 1
    Nov 2009
    18
    Default Sump pit is smelly
    My sump pit has a cover, however it is a big slot to allow the pipes and power cord to have access. There seems to be some foul smells from the pit. Any ideas out there to seal it up? I have seen covers that have holes for the PVC pipes but I assume I would need to take the pump off to feed the PVC through the holes. Should I simply stuff the slot with a towel or something?
    Thanks for any ideas.
