    Pennsylvania
    246
    Question Decision..Decision...Decision...
    I just removed the top of my outdoor Central A/C & Gas furnace unit. [Goodman Unit]
    I need heat exchanger badly. They're cracked.
    I think it is time for me to buy new unit. I don't think hybrid unit is within my price range.
    What do you folks think?
    Goodman heat exchanger....................$826.00
    Goodman package unit
    2.5ton 13 seer/R-22
    69,000btu........................................$ 4115.00
    High efficiency 3.0ton
    15 seer/R-410
    2 stage gas
    70,000btu.......................................$4 995.00
    Aries package unit
    2.5ton 13 seer R-22
    60,000btu.......................................$4 750.00
    Aries package unit
    3.0ton 13 seer R-22
    68,000btu.......................................$4 915.00
    Goodman heat pump package unit
    13 seer R-22 2.5ton
    10kw electric heat back up................$4450.00
    15 seer R-22 2.5ton
    10kw electric heat back up................$4525.00
    Hybrid units
    Carrier hybrid 2.5ton
    13 seer R-22
    60,000btu......................................$55 52.00
    Carrier hybrid 3.0ton
    13 seer R-22
    90,000btu......................................$58 24.00
    "Life does not go by the book, we learn as we go along".
    You only need two tools in life - WD-40 and Duct Tape.
    If it doesn't move and should, use WD-40.
    If it shouldn't move and does, use the Duct Tape.
    Default Re: Decision..Decision...Decision...
    BW ... what if you went with the new exchanger and a new A/C .... probably would half of buying new.
    Pennsylvania
    246
    I'm confuse with your statement.... I think you mean I have separate unit.
    I have Goodman A/C and heating unit. It is complete outdoor unit assembly. I think it is call "self contained unit"....please correct me if I'm wrong.
    it looks like this.......notice the picture below is for a/c and heat pump....I have a/c and gas furnace, anyway, it is nearly identical to mine.
