    Oct 2011
    Denver
    Default Ceramic Cartridge Replacement
    I have a shower panel with a 5 port diverter (1 inlet and 4 outlets - one of which is plugged to act as the off position). The shower recently started leaking and I removed the ceramic catridge but I am unable to find a replacement. It is a 40mm unit with a 4 oring bottom and is the one show in this website
    atrade.com.tw/ArticleShow.asp?ArticleID=395
    Any help locating this cartridge would be most appreciated. I have been to all the stores in Denver!
    6,963
    Default Re: Ceramic Cartridge Replacement
    If you know the manufacturer of the valve, you can take that information and the cartridge to a plumbing supply house - a specialty supplier that caters to contractors not a big box retailer. They should either have to part or be able to order it from the manufacturer for you. If that doesn't work, you could also contact the manufacturer directly and get a replacement from them.
    6,385
    If you are unable to find a replacement part and want to solve your leak, you will need to replace the body, located inside the wall.
    Definately a job for a plumber, who knows how to finish the holes he will make.
    Oct 2011
    Denver
    Unfortunately I do not know the manufacturer, I wish this was that easy. I contacted the company that sold me the shower panel and they said the shower panel is not carried by them any more - no manufacturer etc.. Since it is a shower panel, the valves all all easily accessable but the valve in question is a 5 port transfer valve (1 inlet (from thermo valve) and 4 outlets with one plugged to act as the off position). So I am unable to find the cartridge or a replacement valve.
    T
    6,963
    Quote Originally Posted by doctjh View Post
    T
    Without a manufacturer it will be nearly impossible to identify the valve to find a suitable replacement. It sounds like it's a cheap piece of junk designed and manufactured solely for that shower panel manufacturer or purpose, which means there were never any replacement parts available in the first place. This is why I recommend only purchasing name brand products that you trust.
