    Jul 2009
    14
    Default Sprinkler Backflow leak
    Greetings All,
    I'm not sure what this part does or what it is called, but I believe it is a blackflow device for an old sprinkler system. (can't upload a picture I took for some reason)
    It is leaking and I am wondering if I can simply remove it and cap the ends?
    I'm not using this sprinkler system btw.
    Thanks
    7,911
    Default Re: Sprinkler Backflow leak
    If it's an abandoned sprinkler valve, then yes, you can remove it and cap the lines. You'll need to turn off the water first.
    Do you have an in-ground pool? It could also be a pool supply, in which case you'll want to have it repaired or replaced.
    Jul 2009
    14
    I don't have a pool.
    Many Thanks!
    7,720
    If it's unused just get rid of it and stop the leak. If the riser is in your way, remove it too. Remember the location of the cap, in case you change your mind.
