    Oct 2011
    Question flooring for enclosed porch in MN
    My 1918 farmhouse has an enclosed, 3 season, unheated front porch. It is 25x7 feet. The flooring needs to be replaced. I am wondering if floating laminate or cork will work. If not will vinyl that looks like wood work? Someone at home depot said the top layer might separate. Tile is sounding like the only option, and it really won't fit with the style of the farmhouse. Temps on the porch range from 0 degrees to 100 degrees.
    nova scotia, canada
    1,522
    Default Re: flooring for enclosed porch in MN
    if its fully dried in and heated laminate and engineered hardwood it might be ok however if not youll be tearing up in no time go with tile
    May 2011
    251
    Stick with tile. As mentioned, wood will be problematic as humidity and temperatures change.
    You could also do stamped and/or coloured concrete.
    For tiles, the under layment must be rock solid or it will crack and lift. There's a huge wrap around porch on a old home near here. IT has gorgous hex tile with a really neat pattern. Sadly, the porch has settled and the wood has changed dimensions and buckled much of the tile.
    Sep 2009
    florida
    598
    What about Azek Porch flooring/T&G...or mayby some of the other composite flooring products.....
    http://www.azek.com/azek-porch/
    http://www.aeratis.com/pdf/Installat...ions_07_11.pdf
    http://www.correctporch.com/
    Gizmo
    Hidden Content
    Hidden Content
